编辑目录树之一
本节内容可以参考CaseStudy目录下的文件:目录树管理.Table
假定并不想用表来存储目录结构,而是希望通过一个文本文件存储,并希望能够让修改并保存目录树结构。
实现这样的任务并不复杂,我们假定存储目录树结构的文件名“product.foxtr”,位于项目文件目录下。
设计的步骤为:
1、首先设计一个下图所示的窗口:
2、窗口的AfterLoad事件设置为:
tr As WinForm.TreeView = e.Form.Controls("TreeView1")3、按下表所示设置各按钮的Click事件代码:
| 名称 | 代码 |
| 重命名 | Dim
tr As
WinForm.TreeView tr = e.Form.Controls("TreeView1") tr.Select() tr.BeginEdit() |
| 增加根节点 | Dim
tr As
WinForm.TreeView Dim nd As WinForm.TreeNode tr = e.Form.Controls("TreeView1") nd = tr.Nodes.Add("新节点") tr.SelectedNode = nd tr.Select() tr.BeginEdit() |
| 增加子节点 | Dim
tr As
WinForm.TreeView Dim nd As WinForm.TreeNode tr = e.Form.Controls("TreeView1") nd = tr.SelectedNode If nd IsNot Nothing Then nd = nd.Nodes.Add("新节点") tr.SelectedNode = nd tr.Select tr.BeginEdit End If |
| 插入节点 | Dim
tr As
WinForm.TreeView = e.Form.Controls("TreeView1") Dim nd As WinForm.TreeNode = tr.SelectedNode Dim id As Integer = nd.index If nd.ParentNode Is Nothing Then nd = tr.Nodes.Insert("新节点",id) Else nd = nd.ParentNode.Nodes.Insert("新节点",id) End If tr.SelectedNode = nd tr.Select tr.BeginEdit |
| 上移 | Dim
tr As
WinForm.TreeView = e.Form.Controls("TreeView1") Dim nd As WinForm.TreeNode = tr.SelectedNode If nd IsNot Nothing Then nd.MoveUp() End If tr.Select |
| 下移 | Dim
tr As
WinForm.TreeView = e.Form.Controls("TreeView1") Dim nd As WinForm.TreeNode = tr.SelectedNode If nd IsNot Nothing Then nd.MoveDown() End If tr.Select |
| 左移 | Dim
tr As
WinForm.TreeView = e.Form.Controls("TreeView1") Dim nd As WinForm.TreeNode = tr.SelectedNode If nd IsNot Nothing Then nd.MoveLeft() End If tr.Select |
| 右移 | Dim
tr As
WinForm.TreeView = e.Form.Controls("TreeView1") Dim nd As WinForm.TreeNode = tr.SelectedNode If nd IsNot Nothing Then nd.MoveRight() End If tr.Select |
| 删除 | Dim
tr As
WinForm.TreeView = e.Form.Controls("TreeView1") Dim nd As WinForm.TreeNode = tr.SelectedNode If nd IsNot Nothing Then nd.Delete End If tr.Select |
| 保存 | Dim
tr As
WinForm.TreeView = e.Form.Controls("TreeView1") Dim fn As String = ProjectPath & "Product.foxtr" tr.Save(fn) |
4、实际上,重命名节点修改的只是节点标题,而不是节点名称,所以我们还需要在AfterEditNode事件中设置代码,使得节点名称和标题保持一致:
e.Node.Name = e.NewText
5、下图是设计效果,用户可以并保存修改目录树结构:
