多层分组
下面的代码同样是根据产品和雇员分组,但是分两层:
doc
As New PrintDoc
Dim rt As
New prt.RenderText
Dim ra1 As
New prt.RenderArea
Dim ra2 As
New prt.RenderArea
'设置一级分组
ra1.Style.Spacing.Bottom = 2
ra1.DataBinding.DataSource = BindTables("订单")
'将容器绑定到订单表
ra1.DataBinding.Grouping.Expressions.Add("Fields!产品.Value")
'增加产品分组
'打印一级分组的组名
rt.Text= "产品:[Fields!产品.Value]"
rt.Style.FontSize = 14
rt.Style.FontBold = True
rt.Style.Spacing.Bottom = 2
ra1.Children.Add(rt)
'设置二级分组
ra2 = New Prt.RenderArea
ra2.Style.Spacing.Bottom = 2
ra2.DataBinding.DataSource = ra1.DataBinding.DataSource
'将容器绑定到订单表
ra2.DataBinding.Grouping.Expressions.Add("Fields!雇员.Value")
'增加雇员分组
ra1.Children.Add(ra2)
'二级分组的容器要加到一级分组的容器中
'打印二级分组的组名
rt = New prt.RenderText
rt.Text= "雇员:[Fields!雇员.Value]"
rt.Style.FontSize = 12
ra2.Children.Add(rt)
'打印明细
rt.Text = "日期:[Format(Fields!日期.Value,""yyyy-MM-dd"")]
客户:[Fields!客户.Value] 数量:[Fields!数量.Value]"
rt.DataBinding.DataSource = ra2.DataBinding.DataSource
'不能漏掉这一行
ra2.Children.Add(rt) '添加到二级分组中
doc.body.Children.Add(ra1)
doc.Preview()
执行结果:
本页地址:http://www.foxtable.com/webhelp/topics/1259.htm
