Split
用指定的分隔符将字符串分隔成一个字符串数组。
Split(Value)
Value: 用于分割字符串的字符或字符数组。
Dim Multi As String = "ab|cd|ef"
Values() as String
Values
= Multi.split("|")
Index As Integer = 0 To Values.Length - 1
    Output.Show(Values(Index
在命令窗口执行上述代码之后,输出结果是:
ab
cd
ef
分割字符可以是一个数组,例如:
Dim Value As String = "foxtable|access/foxpro|excel/egrid"
sps() As Char = {"|","/"}
Names() As String  = Value.Split(sps)
Each name As String In Names
Output.Show(Name)
foxtable
access
foxpro
excel
egrid
可以看到,"|"和"/"都参与了内容的分割
本页地址:http://www.foxtable.com/webhelp/topics/0245.htm
